  New Posts New Posts RSS Feed - almera ignition barrel
silky1525 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote silky1525 Quote  Post ReplyReply Direct Link To This Post Topic: almera ignition barrel
    Posted: 04 February 2012 at 18:11
the ignition barrel on my almera has stated to stick , i put the key in and its fine , when i try to take it out its stuck and a have to wiggle it and force it out . iver tried spare key and its the same . cane the barrel only be replaced and then take the chip out of the old key and put it in the new key that comes with the barrel .
 any help appreciated
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mick Quote  Post ReplyReply Direct Link To This Post Posted: 08 June 2012 at 02:50
You can usually sort this issue by using some WD40 or lube oil in the ignition barrel. It will be one of the key tags inside the barrel that is sticking and not releasing the key.
This page was generated in 4.266 seconds.
