Door Lock |
Expert
New Member Joined: 18 May 2010 Location: United Kingdom Status: Offline Points: 15 |
Posted: 31 May 2010 at 09:58 |
KEY FOB PROGRAMMING
NISSAN SYSTEM DESCRIPTION The Central Door locking is controlled by the Multi-Remote Control system which controls the door locking, door super locking and hazard reminder. When the doors are locked and unlocked the unit flashes the hazard lights once for lock and twice for unlock. A maximum of four remote controls are allowed to be programmed. ALMERA ALMERA TINO PRIMERA MAXIMA MICRA SERENA VANETTE CARGO TERANO II Ensure all the doors have been unlocked, either by using a good transponder key or remote control plip key. Procedure 1. Turn the ignition switch from Position 0 to ON 6 times within 10 seconds. 2. Then turn ignition switch to OFF position. Leave key in ignition switch. 3. After 2 seconds, the system will enter programming mode and will flash the warning lights twice. 4. Press and HOLD the unlock button on the Plip. 5. While pressing the unlock button, press the lock button 3 times. 6. Release the unlock button. 7. The warning lights will flash once to indicate successful programming. 8. Repeat procedure 4 to 7 for up to 4 plip key’s. 9. When completed turn ignition ON, and the warning lights will flash 2 times. 10. Remove key, and check all plip key’s for operation. NOTE : The programming mode will stop when either the ignition is switch ON, 4 plip keys have been programmed or no input signal either from the switch or plip keys has been received for 120 seconds. |
Famikuns
New Member Joined: 21 May 2010 Status: Offline Points: 27 |
Thanks The remote control is not working again at all, but with the key it can open all the doors but it dosn't lock all the doors except the driver's side. |
crazytaxi
Management Board Cleaning God Joined: 26 August 2006 Location: Salford Status: Offline Points: 489 |
Again a bit more info please.
Do you mean it wont lock all doors using the key or the remote fob? Just one door not locking/unlocking? Drivers door is the only one that locks off the key? |
Famikuns
Hello Thanks for your reply, I'm using Primera P10 model and for sometime now my central door lock is not working normal again. what can i do. |
Management General Dogs Body Joined: 08 October 2005 Location: Cheshire Status: Offline Points: 2113 |
Can you supply a bit more detail please?
Famikuns
Hello Pls, can anybody tells me what to do my central lock door is not working again. Thanks |
