Forum Home Forum Home » Model Specific » Primera
  New Posts New Posts RSS Feed - Door Lock
Door Lock
Expert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Expert Quote  Post ReplyReply Direct Link To This Post Topic: Door Lock
    Posted: 31 May 2010 at 09:58
KEY FOB PROGRAMMING
NISSAN
SYSTEM DESCRIPTION
The Central Door locking is controlled by the Multi-Remote Control system which controls
the door locking, door super locking and hazard reminder. When the doors are locked and
unlocked the unit flashes the hazard lights once for lock and twice for unlock.
A maximum of four remote controls are allowed to be programmed.
ALMERA
ALMERA TINO
PRIMERA
MAXIMA
MICRA
SERENA
VANETTE CARGO
TERANO II
Ensure all the doors have been unlocked, either by using a good transponder key or remote
control plip key.
Procedure
1. Turn the ignition switch from Position 0 to ON 6 times within 10 seconds.
2. Then turn ignition switch to OFF position. Leave key in ignition switch.
3. After 2 seconds, the system will enter programming mode and will flash the warning
lights twice.
4. Press and HOLD the unlock button on the Plip.
5. While pressing the unlock button, press the lock button 3 times.
6. Release the unlock button.
7. The warning lights will flash once to indicate successful programming.
8. Repeat procedure 4 to 7 for up to 4 plip key’s.
9. When completed turn ignition ON, and the warning lights will flash 2 times.
10. Remove key, and check all plip key’s for operation.
NOTE : The programming mode will stop when either the ignition is switch ON, 4 plip keys
have been programmed or no input signal either from the switch or plip keys has been received
for 120 seconds.
Famikuns View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Famikuns Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2010 at 09:29
Thanks
The remote control is not working again at all, but with the key it can open all the doors but it dosn't lock all the doors except the driver's side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote crazytaxi Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 20:58
Again a bit more info please.
Do you mean it wont lock all doors using the key or the remote fob?
Just one door not locking/unlocking?
Drivers door is the only one that locks off the key?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Famikuns Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 15:42
Hello
Thanks for your reply, I'm using Primera P10 model and for sometime now my central door lock is not working normal again. what can i do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mick Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 03:52
Can you supply a bit more detail please?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Famikuns Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2010 at 18:50
Hello
Pls, can anybody tells me what to do my central lock door is not working again.
Thanks
This page was generated in 3.500 seconds.
