Condensation |
lynall
New Member Joined: 31 August 2010 Status: Offline Points: 49 |
Posted: 16 October 2010 at 12:53 |
I lied it did it again last night
Lynall |
lynall
Havent looked at pollen filter yet, but did get car up on
ramp straight after arriving at work with a/c on and water was dripping from the drain tube and its clear so not that. But was washing car the next day and when squeeging the water off i noticed a couple of drops of water on the inside of the window so opened door and sure enough the handle was pointing down and not up so was half a turn down. I dont think the washing was the cause more the rain we have had lately and the damp overnight, carpets werent damp so defo think just damp air. Has been fine for 3 days so far no a/c on and clear screens all round, obviously only time will tell. Must check pollen filter as well! Lynall Edited by lynall |
Guests
Guest |
you dont need the carpets up the pollen filter is behind the glovebox if you can stand on your head you can get to it. otherwise pop the glove box out its a bit of a faff to get out with sqeezing the top down and twist the botton up |
lynall
Good point its climate and one of the the first things i
tried was to have the recirc button set for outside air this didnt make any difference. I will give you an example get in car at 6.15 am and drive off wipers are going as they are set to auto and the screen constantly needs clearing this is weatehr outside not inside! I also set the climate to clear the screen this goes flat out and switchs the air con on and clears the screen inside fast. Once clear i switch of the clear screen button and the a/c goes off, after a couple of miles the car slowly starts to mist up if i look over my shoulder when the screen just starts to mist at the edges the side windows are covered, a/c back on and another 2 miles or so and its clear again. Its not a short commute 12 miles and the car gets a good work and full running temperature. I think i will have the carpets up this weekend and try and find the pollen filter. I had the drivers side mat up a few weeks ago to fit the seat heaters and it was dry under that side. Lynall |
crazytaxi
Management Board Cleaning God Joined: 26 August 2006 Location: Salford Status: Offline Points: 489 |
Was thinking filter myself too, as far as i know its located behind the glovebox. check the condition of it, they can be washed but they are not too expensive anyway, just make sure if you do wash it to to make sure it's dry before you put it back.
gt786
Senior Member Joined: 01 December 2005 Location: United Kingdom Status: Offline Points: 175 |
does your micra have a pollen filter? you could try changing that?
Guests
Guest |
should be an easy fix, i take its normal air con and not climate you can set the air circurulation to re-use the air in the car, or bring in fresh air from the outside if you set to fresh air it should balance the temp inside the car when it gets cold basicly all you need todo is push a button (or push a slider) |
lynall
Getting on my nerves!
I am having to run the a/c to keep the screens clear which is not the end of the world but it kills what little power the car has! I have done a quick scout around and cannot find any damp spots or wetness anywhere. Ive had plenty of cars with a/c and whilst this weather is a pain this is without a doubt the worst car for this yet. Any ideas? Is this a common Micra thing and how do people without a/c clear their screens? Lynall |
