  New Posts New Posts RSS Feed - Water being blown out of radiator
suzannestaite View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote suzannestaite Quote  Post ReplyReply Direct Link To This Post Topic: Water being blown out of radiator
    Posted: 25 November 2010 at 11:34
I have a 2005 Nissan Pathfinder which is used mainly for town driving. Occasionally (probably about 6-8 times a year) the water is blown out of the radiator into the reservoir bottle, this seems to happen for no apparent reason and not whilst under any strain (ie towing).  Any ideas???Reservoir
SS
NOTEFEVER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NOTEFEVER Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2010 at 11:48
Check the thermostat.
Check hoses and try to see if there is air traped inside
the hoses and radiator.
(Hope you are not using water to refill it) Paraflu is ok.
sentiplum View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sentiplum Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2011 at 05:00
have you ever tried checking your air filter? or maybe you radiator? had the same problem with mine, though that was years ago. I had it replaced then with a spectra radiator.
Edited by sentiplum
for those who cant, then you cant. website for kids school.
This page was generated in 3.297 seconds.
