Forum Home Forum Home » Model Specific » Note
  New Posts New Posts RSS Feed - Air conditioning non-existent
scottmac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scottmac Quote  Post ReplyReply Direct Link To This Post Topic: Air conditioning non-existent
    Posted: 03 June 2011 at 15:15
I have a 2006 Note SVE with climate control air-con, the heating side of this seems to work fine but the cooling side is non-existent, when you switch it on it just feels like a high powered fan blowing outside temperature air. Has any one had any similar problems? I know Kwik fit do an air-con recharge service but is this jusy another kwik fit con?
Edited by scottmac
mdvineng View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdvineng Quote  Post ReplyReply Direct Link To This Post Posted: 03 June 2011 at 17:00
Hi, you could try an independant or regas it yourself. between £20<50 for a refill bottle and follow the instructions, I've used this on two cars Ok but if your system has developed a leak, it won't last long. best to exercise the air con at least once a month to keep the seals elastic.
both motorcycle wheels drifting with the power on feels great
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 03 June 2011 at 18:28
take it to a garage with an air con setup who know what there doing not the quick fit monkeys
a leak test with uv die will find any leaks if any it shouldnt be too dear, as soon as it toped up if theres any pressure drop their see it. The climate on my note turns the car into an icebox in 4-5 mins on a very hot day tbh i like to have the windows down rather than the CC
ph47mf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ph47mf Quote  Post ReplyReply Direct Link To This Post Posted: 14 June 2011 at 15:36
my dad's almera is usually topped up kwik fit people and they seem to be fine. just dont let them touch anything else. their technicians only know what they sell i.e. changing tyres, changing oil etc.
This page was generated in 6.094 seconds.
