Engine Problems |
collinsc
New Member Joined: 14 August 2010 Status: Offline Points: 27 |
Posted: 06 August 2011 at 17:56 |
it has done it once before - the drive belt had snapped.
the radiator pressure cap. 13 in the picture... http://www.clubnissan.co.uk/forum/forum_posts.asp? TID=3948&PN=0&TPN=1 thanks |
Guests
Guest |
over heating could be a number of things if it hasnt done it before i would check the rad cap, if its letting passed the system will loose pressure/water and tend to over heat causing the fan to kick in where did you top the coolant up ?? the expansion bottle ?? |
collinsc
Took it out again today and the engine is over heating
(radiator gauge was heading to 3/4) - can anyone advise!? thanks |
collinsc
Hi
Having a problem with my Nissan Micra Vibe (51 Plate). I topped up the radiator with coolant (as id not done it for a while) - about 50/50 water to coolant. I took the car out for a 10 min drive and when i came back i heard some spurting and it sounded like the engine fan was going (more so than normal). The engine itself felt very warm to the touch (is that normal for a short drive!?) I may have some technical terms above wrong as i'm not that knowledgeable! Prior mail for reference: http://www.clubnissan.co.uk/forum/forum_posts.asp? TID=3948 The other minor problem i have is that after filling the washer reservoir it appeared to mostly leak out - whilst i was stood there - yet you look in the reservoir and you can see a certain amount of fluid in the bottom. Might this mean there is a hole in the reservoir, but half way up!!!?? Advice very much appreciated. Thanks |
