  New Posts New Posts RSS Feed - Engine Problems
Engine Problems
collinsc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote collinsc Quote  Post ReplyReply Direct Link To This Post Topic: Engine Problems
    Posted: 06 August 2011 at 17:56
it has done it once before - the drive belt had snapped.
the radiator pressure cap. 13 in the picture...
http://www.clubnissan.co.uk/forum/forum_posts.asp?
TID=3948&PN=0&TPN=1
thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2011 at 15:45
over heating could be a number of things if it hasnt done it before i would check the rad cap, if its letting passed the system will loose pressure/water and tend to over heat causing the fan to kick in
where did you top the coolant up ?? the expansion bottle ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote collinsc Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2011 at 14:29
Took it out again today and the engine is over heating
(radiator gauge was heading to 3/4) - can anyone advise!?
thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote collinsc Quote  Post ReplyReply Direct Link To This Post Posted: 05 August 2011 at 21:35
Hi
Having a problem with my Nissan Micra Vibe (51 Plate). I
topped up the radiator with coolant (as id not done it
for a while) - about 50/50 water to coolant. I took the
car out for a 10 min drive and when i came back i heard
some spurting and it sounded like the engine fan was
going (more so than normal). The engine itself felt very
warm to the touch (is that normal for a short drive!?)
I may have some technical terms above wrong as i'm not
that knowledgeable!
Prior mail for reference:
TID=3948
The other minor problem i have is that after filling the
washer reservoir it appeared to mostly leak out - whilst
i was stood there - yet you look in the reservoir and you
can see a certain amount of fluid in the bottom. Might
this mean there is a hole in the reservoir, but half way
up!!!??
Advice very much appreciated.
Thanks
This page was generated in 3.031 seconds.
