  New Posts New Posts RSS Feed - Micra Petrol 2004. P0340 error
findmak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote findmak Quote  Post ReplyReply Direct Link To This Post Topic: Micra Petrol 2004. P0340 error
    Posted: 11 September 2011 at 19:44
I have the engine light on in the 2004 Micra 1.4 Petrol
and it has the error code P0340 only.
I took out the Camshaft sensor and it has a tiny hole in
the end that goes into the engine, not sure if it suppose
to have this?
Also I noticed that once I clear the error and restart
the car there is no error until I gas the car, then it
comes back.
Should I replace the camshaft sensor?
Also if the car stalls, then it will not restart (the
engine turns) unless I wait for 10 seconds, then it will
start. is this due to the sensor?
It has erratic throttle from cold start, but if I gas it,
it becomes normal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2011 at 20:48
from what you discribe its a faulty sensor and yes thay are a common fault, dont buy a cheap sensor get a proper nissan part or a NTK one
an incorrect signal to the esu will make the car under fuel/over fuel no signal at all the car will crank over but not fire if the cold start fault doesnt clear up after the cam sensor is changed i would look at the coolent temp sensor (CTS)
This page was generated in 2.750 seconds.
