Forum Home Forum Home » Model Specific » Terrano
  New Posts New Posts RSS Feed - Terrano 11 gearbox
Terrano 11 gearbox
RIBVAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RIBVAN Quote  Post ReplyReply Direct Link To This Post Topic: Terrano 11 gearbox
    Posted: 13 September 2011 at 22:40
We had a problem yesterday the gear lever locked so we
could not engage any gear, the unit was in two wheel drive.
If I turned the engine off I could engage all gears and
drive but not change gear again. Up to then driving was no
problem
RAC attended and had the same issue but I moved car to
allow a tow but before this the gears all worked OK, Been
into a garage and they find no driving faults. No leaks no
loss of clutch pedal pressure at any time
Any ideas what happened and do I need to get work done.
Taz1973 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Taz1973 Quote  Post ReplyReply Direct Link To This Post Posted: 11 October 2011 at 20:21
Gear linkage ?
Terrano's go everywhere slow and nowhere fast!!
Terrano Bry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terrano Bry Quote  Post ReplyReply Direct Link To This Post Posted: 24 November 2013 at 23:53
Also i think there is a spring at the bottom of the gear lever.You would have to remove the center console to get to it though.
This page was generated in 3.891 seconds.
