  New Posts New Posts RSS Feed - NSR door wont open
NSR door wont open
topskills View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote topskills Quote  Post ReplyReply Direct Link To This Post Topic: NSR door wont open
    Posted: 13 August 2012 at 12:11
neither handle on the NSR door (2005 pathfinder) will operate the door so im assuming a critical component had decided to break! both handles move freely but dont engage.
has anyone any idea on how to open the door as ive had a good look around and can see no obvious way without causing damage??
any help greatly appreciated!
Ratchet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ratchet Quote  Post ReplyReply Direct Link To This Post Posted: 14 August 2012 at 03:30
Hello topskills,
The only way is to remove the inner door card as bast as you can, then reach in and try to pull the release rod for the inside door handle.
If this done not work then you may have a lock problem, meaning the lock motor mechanisum is not moving to bring the release mechanism back into play to let you open the door.
Either way you will have to take the door card off as best as you can to get at either the release rod or the lock motor.
Normally it's just a dirty plug on the motor, a squirt of WD40 in the plug and a good wiggle sorts that out so you can get the door open to let you get at the motor and plugs to clean them up.
Hope this is of some help to you.
Let us know if we can help more with this and we'll do our best to help you.
All the best.
Qualified ABC Diploma Level 1 & City & Guilds Level 2 Mechanic
This page was generated in 5.109 seconds.
