Rattly engine |
aylnissan
New Member Joined: 29 December 2010 Location: United Kingdom Status: Offline Points: 7 |
Posted: 06 January 2011 at 18:33 |
It may be woth checking the top chain tensioner first. Many of the early shape x-Trails suffered with a slack top hydraulic tensioner (at full extension ) when the car is cold.
John
New Member Joined: 16 December 2010 Location: United Kingdom Status: Offline Points: 1 |
2005 x-trail have the same problem, chattering noise when
engine cold but seemed to go away when warmed up. I first noticed this when the car was 2 years old, only to be told to put some WD40 onto the pulleys, this did stop it but only for about 3/4 days. As stated earlier it is still there but much more severe and no one wants to pinpoint what is causing or what can be done. VERY ANNOYING. |
Guests
Guest |
Any you like tbh as long as its to nissans specs for you engine as for the oil filter use a genuine nissan one then the dealer is none the wiser to what youve done
Olly
New Member Joined: 11 September 2010 Location: United Kingdom Status: Offline Points: 3 |
Thanx for your reply, have you any suggestions on the best
oil to use. |
Guests
Guest |
Welcome to CN it could be a number of things from the cam, lifters or even the timing chain first thing i would do is flush the oil and do a oil and filter change and see if it less noisy if its a diesel thay rattle a fair bit esp after 20-30k miles or so as the enginge starts to bed in and lossen up a bit |
Olly
Last year we purchased a nissan xtrail columbia 07 and we
have found that on start up it has a very noisy engine, in fact it sounds like a bag of spanners, this only lasted a couple of miles but recently seems to be rattly most of the time, we have had it back to our local nissan dealer and they say there is nothing wrong, could anybody please advise as this now driving us mad. |
