Forum Home Forum Home » Model Specific » X-Trail
  New Posts New Posts RSS Feed - Rattly engine
Rattly engine
aylnissan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aylnissan Quote  Post ReplyReply Direct Link To This Post Topic: Rattly engine
    Posted: 06 January 2011 at 18:33
It may be woth checking the top chain tensioner first. Many of the early shape x-Trails suffered with a slack top hydraulic tensioner (at full extension ) when the car is cold.
John View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Quote  Post ReplyReply Direct Link To This Post Posted: 16 December 2010 at 18:24
2005 x-trail have the same problem, chattering noise when
engine cold but seemed to go away when warmed up. I first
noticed this when the car was 2 years old, only to be told
to put some WD40 onto the pulleys, this did stop it but
only for about 3/4 days. As stated earlier it is still
there but much more severe and no one wants to pinpoint
what is causing or what can be done. VERY ANNOYING.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2010 at 13:33
Any you like tbh as long as its to nissans specs for you engine as for the oil filter use a genuine nissan one then the dealer is none the wiser to what youve done
Olly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Olly Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2010 at 13:04
Thanx for your reply, have you any suggestions on the best
oil to use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2010 at 11:55
Welcome to CN
it could be a number of things from the cam, lifters or even the timing chain
first thing i would do is flush the oil and do a oil and filter change and see if it less noisy
if its a diesel thay rattle a fair bit esp after 20-30k miles or so as the enginge starts to bed in and lossen up a bit
Olly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Olly Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2010 at 10:59
Last year we purchased a nissan xtrail columbia 07 and we
have found that on start up it has a very noisy engine, in
fact it sounds like a bag of spanners, this only lasted a
couple of miles but recently seems to be rattly most of the
time, we have had it back to our local nissan dealer and
they say there is nothing wrong, could anybody please
advise as this now driving us mad.
This page was generated in 4.908 seconds.
